Rasul_S_Intel
7 years agoHow do I build on top of an IP generated example design?
I am building a project that uses an EMIF to push data from a transceiver to DDR3 memory. I took the following steps and now I am stuck: I generated the EMIF IP I generated the example design for ...
MuhammadAr_U_Intel
Contributor
7 years agoHi,
Example designs are generated with two set of files, one for hardware implementation and second for simulation purpose. you should be able to find the readme file with commands to guide you on next steps.
Yes, example designs are generated with simulation scripts you will be able to bring up the simulating using the script for Modelsim it will be "msim_setup.tcl" You can take it as a baseline and build up your design on top of it by adding other components.
You should refer to example design user guide to answer the questions related to file structure and file details.
https://www.intel.com/content/altera-www/global/en_us/index/documentation/pvu1502901260167.html
Let me know if this is helpful to address your question.
Arslan
