Littlerice32
5 years agoHow do I avoid using a specific LAB or ALM in Quartus Prime?
For example, I don't want to use a LAB named "LABCELL_X66_Y55_N6".
How do I let Quartus Prime know this, and avoid using this LAB in compiling my design?
Thank you.
Littlerice32
5 years agoYes, the data path is within the same LAB cell, Quartus II still deliver a long routing path. (10x larger than other path)
Is it a normal situation for a low-speed (32MHz) and low-utilization (27%) design?
Could you give me some opinions for explaining why Quartus II did this?
sstrell
5 years agoCan you show the timing report details for the long path (including the routing and logic elements involved)? The HDL for that part of the design? RTL or Tech Map Viewer schematic?
Do you have any relevant assignments in the Assignment Editor that might be forcing this?
More info is needed to figure out what is going on here.
