17 years agoDepends on what you try to achieve. In my view both protocols can be handled by a nearly identical receiver or transmitter design. If you want to connect a "PCM" device to an existing SPI host (microprocessor, not FPGA) some adaption may be necessary. You should tell, which are the data source and sink in your communication problem.
