13 years agoHow connect my data to pcie interafce in Qsys?
I saw many altera's design examples, such as pcie design with Qsys as attached file shows. All of these examples don't show any interface to user logic outside of Qsys. I'm a Qsys newer, so i don't k...
13 years agoPossibly the easiest approach would be to add a dual-port FIFO within your Qsys system and to export the write-side Avalon-MM Slave port so that the wires appear in your Qsys top level module. Then, hook your external logic to those wires to push the data into the Qsys FIFO. You can also do things like add PIO components to control your external logic, if needed.
Alternatively, wrap your existing logic into a Qsys custom component and add an Avalon-MM Slave port to provide access to your existing FIFO, or possibly control/status registers for your custom logic.
