14 years ago
how can we generate post mapping netlist file when using STRATIX IV
I usually generate a Verilog Quartus Mapping file (vqm) with a FPGA Cyclone II in order to win time of Analysis&synthesis when i use the vqm file generated in other project
NOW I use FPGA STRATIX IV E and this option isn't accessible .
So is there any other method to generate a post mapping netlist file?
Thank you for your help
    Open the assignments -> Design Partition Window, then right click on the top partition and write out a .qxp file. You should be able to add that to the other project like a source file.
    (An easier way is to put a partition on that hierarchy in the new project, and just set it to post-synthesis. It will synthesize it the first time, but shouldn't on subsequent compiles as long as the contents don't change.)
