8 years agoHow can we do pipelining between CPU thread and FPGA kernel?
I want to do pipelined processing between the host and FPGA. Say I have kernel0 implemented on host while kernel1 implemented on FPGA. Kernel0 may generate 1000 data where kernel1 will process t...
8 years ago --- Quote Start --- Many thanks, I completely missed this section. Any idea on the latency/throughput compared with typical global memory accesses ? --- Quote End --- If you have access to ACM, check this paper from Altera regarding implementation of host pipes: https://dl.acm.org/citation.cfm?id=3078182
