BLADI
7 years agoHow can i use m25p32 flash, quartus only have epsc16 or epcs64, there is no Similar device epcs32!Is there a configuration file?
How can i use m25p32 flash in quartus ?there is only have epsc16 or epcs64, there is no Similar device epcs32!Is there a configuration file? i program ep4ce40 by jic file
epcs16 epcs64 and m25p32 ,it is same controlling method, and same sector size, only difference number of sectors!
- BLADI
- Vicky1
Please conform the below solution from below links,
- https://forums.intel.com/s/question/0D50P00003yySq0SAE/programming-an-m25p32-serial-flash-using-quartus-programmer-131?t=1542935553572
- https://forums.intel.com/s/question/0D50P00003yyM8QSAU/problem-with-programming-the-m25p32-using-a-jam-file
I hope it may help.
Best Regards
Vikas Jathar
