How can i turn off the optimization completely
May I know any update?
Should I considered as case to be closed?
Vicky
- MHamz17 years ago
Hi, Vicky I tested the logic using testbench and the resutls were satisfactory, in case of CPLD the result in different, I am facing another issue in using the same CPLD, and I belive that it may be due to the optimizations enabled in quartus by default, I tried turning off the "VHDL state machine extraction" feature but got no success.
If the line "testled <= NOT testled" is commented then the behavior of RTL becomes change I have observed a change in the net-list as well.
CONFIGURE_ADC : process(clk) is
variable fifo_memory : fifo_memory_type := (X"04",X"13");--(X"08",X"7B");
variable read_memory : read_data_type := (X"00", X"00", X"00", X"00");
variable fifo_head : integer range 0 to 1 := 0;
variable read_head : integer range 0 to 3 := 0;
variable counter : integer range 0 to 65535 := 0;
begin
if rising_edge(clk) then
if(microseconds > 3000000) then
case confstate is
when X"0" =>
fifo_head := 0;
cs_n <= '0';
testled <= NOT testled; -- if this line is commented or removed the code starts misbehaving and state machine does not propagate in the required manner
if(busy_transfer = '0') then
read_head := 0;
read_memory(read_head) := spi_rx_data;
spi_tx_data <= fifo_memory(fifo_head);
confstate <= confstate + 1;
else
confstate <= X"0";
end if;
when X"1" =>
trigger_transf <= '1';
fifo_head := 1;
when X"2" =>
if(busy_transfer = '1') then
trigger_transf <= '0';
end if;
