How can i turn off the optimization completely
What optimization are you referring to? What is the issue? Posting some code and more details about the exact issue would help.
#iwork4intel
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity Control is
Port (
-- INPUT INTERFACES
CLK : in std_logic; -- system clock Input
PS1_Fail : in std_logic; -- PS1 Fail
PS2_Fail : in std_logic; -- PS2 Fail
Reset : in std_logic; -- Reset
-- OUTPUT INTERFACES
PS_Fail_Detect : buffer std_logic :='1'; -- Gates PS Fail Detect Output
end Control;
architecture Behavior of Control is
SIGNAL PS_Trigger : std_logic := '0'; -- OR Gated fault Output
begin
HANDLE_CONTROL : process (CLK)
begin
if(rising_edge(CLK)) then
PS_Trigger <= (PS1_Fail or PS2_Fail); --PS1_Fail & PS1_Fail are grounded for verification
end if;
end process;
TRIGGER_PSFAULT : process(CLK)
TYPE StateMachine IS(LatchFault,WaitForReset); --state machine data type
VARIABLE FDState : StateMachine := LatchFault; --State machine variable
begin
if(Reset = '1') then
case(FDState) is
when LatchFault =>
if (PS_Trigger = '1') then -- how can this line return true if PS1_Fail and PS2_Fail are low
PS_Fail_Detect <= '0'; -- on startup this signal becomes low, once I give a reset everything works good
FDState := WaitForReset;
else
PS_Fail_Detect <= '1';
end if;
when others =>
null;
end case;
elsif(Reset = '0') then
FDState := LatchFault;
end if;
end if;
end process;
end Behavior;
