16 years agoHow can I split bus in Quartus?
I am trying to split the bus from nios to interconnect with the 4bit counter but I cannot find the way. Is possible? please see the picture!
11 years agoThe problem is that the 2D bus coming out int8 is getting separated to single wires when they connect to nios_system. When you connect those buses to nios_system use the bus drawing option (thick line) because right now you are trying to funnel 12 wires into 1 which is why Quartus is complaining.
I have never tried round 2D bus lines in a schematic before so I'm not certain what indexing you need to use so you might need to use adc[0][11..0], adc[1][11..0], etc... when connecting to nios_system.
