16 years agoHow can I split bus in Quartus?
I am trying to split the bus from nios to interconnect with the 4bit counter but I cannot find the way. Is possible? please see the picture!
16 years agoIf I understood the question correctly then do this:
1) From the QA port draw a single line out that doesn't connect to anything and name it "counter[0]" 2) Do the same with the QB, QC, and QD ports and name them counter[1], counter[2], and counter[3] 3) Draw a bus line to the SOPC Builder system that doesn't connect to anything else and name it "counter[3..0]" Quartus II knows that those individual signals connect to the SOPC Builder system since they share the same name. Alternatively you could just wire the four outputs into a bus line within the counter and not have to worry about doing this in the schematic.
