JBadm
6 years agoHow can I solve this issue to do with insufficient RAM even though I have loads of sufficient RAM and memory to run Quartus. It is also worth mentioning that I have had this working previously.
Error (293007): Current module quartus_map ended unexpectedly. Verify that you have sufficient memory available to compile your design. You can view disk space and physical RAM requirements on the System and Software Requirements page of the Intel FPGA website (http://dl.altera.com/requirements/).
1 Reply
- AnandRaj_S_Intel
Hi Jordan,
Are you asking a question or providing a solution?
If you have enough RAM as per requirement and still facing the problem.
- Clear cache memory, close all the applications running and restart the system.
- Launch only Quartus application & run the full compilation. Don't launch any other application including Modelsim.
Anand
