sli30
7 years agoHow can I see the place&route on FPGA for OpenCL file?
Dear all, Typically for RTL code, we can use chip planner in Quartus to see the resource place&route. My question is now I'm using commend aoc to generate the *.aocx file (aoc *.cl -o *.aocx). It wi...
sli30
7 years agoDear Arslan and HRZ,
Thank you so much for your help. Finally I got the place&route on Chip Planner. The reason I want to see chip planner is that I want to see each OpenCL kernel's corresponding physical position on the chip. Even though I got the overview of chip planner, I still can not tell which area belongs to which kernel. Is there any way to easily distinguish the area for different kernels? Maybe I should ask this question: Different kernels distributed in separate group of areas or tangled each other and cannot distinguished? Many thanks.
