OHarb1
6 years agoHow can I run quartus_sh 19.3.0 or better in Docker?
When I try to run quartus_sh inside Docker, I get the crash below. Any ideas on how I can address this? quartus_sh --lower_priority --flow compile top Info: ***************************************...
OHarb1
6 years agoIt would obviously make Quartus a lot more user-friendly if it wasn't necessary to hunt down this workaround:
I can sweep the problem under the carpet with these Dockerfile incantations:
+RUN apt-get -y --no-install-recommends install libtcmalloc-minimal4
+ENV LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libtcmalloc_minimal.so.4
