MHusz
8 years agoHow can I properly set the triggers/storage qualifiers in Signal Tap II so the data I see after it is run is from the initial trigger to the end of the sample depth that I specify?
For context, I'm having trouble figuring out how to configure the Wolfson DAC with the I2C interface with my DE1-SoC. I'd like to see what my program is sending to the DAC via the I2C and where the c...
Rahul_S_Intel1
8 years agoHi,
Kindly provide the screen shot of your signal tap and you can set the trigger condition on the signal tap window for example High , Low . In most cases by default it will be dont care, so requesting to change to expected value to triger.
Hope it helps.
Rahul S
