zch
7 years agohow can i eliminate this ----> Error (10482): VHDL error at Controller.vhd(17): object "UNSIGNED" is used but not declared
a_x_h_75
Contributor
7 years agoThe clue is in the error - declare it - either as a signal or a variable within the process...
Unless you're using numeric_std package. In which case this becomes a defined type. So you'll need to change the name of your signal.
Cheers,
Alex
