18 years ago
How can I change configuration via package constant?
I have a problem, a style probem.
In my design, some blocks might switch from a more performing and more resource consumming architecture to a less performing and less occupying one.
Which architecture will win is still to be decided.
I wish I could switch between those architectures by changing the value of a constant in a global package and having it work in the configuration section of the top level architecture.
Something like:
configuration CFG_TOP of TOP_FILE is
for schematic
for I_1,I_2: code_1
use configuration slow_cfg when global_switch='1' else
use configuration fast_cfg;
end for;
end for;
end CFG_TOP;
Should this global package constant work, I could switch several blocks from architecture to architecture at the same time, having not to worry for forgetting a code.
Can anybody help me to solve this problem?
Thank you,
Simona.
