13 years ago --- Quote Start --- Are b, and d* registers? --- Quote End --- b is a register. d is not. --- Quote Start --- Quartus does have timing driven synthesis and fitting: you specify timing constraints and the software tries to optimize the design as much as needed until your constraints are met. --- Quote End --- So, how would I specify a timing constraint that would force c to change to d within, let's say, 5 ns of b changing?
