JFrye7
6 years agoHooking up Mentor AXI BFM to Platform Designer Simulation
I have a platform designer system where I have a Mentor Graphics AXI3 Master. I have successfully created the test bench system, but when I go to run the simulation script (either in ModelSim-Altera ...
RichardT_altera
6 years agoHave you Generate VHDL simulation and synthesis files for your system? Which Quartus version are you using? (pro / standard)
You can try to go through the simulation flow and check is there anything amiss.
Reference (pro): https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-20093.pdf
