8 years agoHLS support in Lite and Standard versions
Hello all! I installed Quartus 17.1 Lite version (with the problems that I described here (https://www.alteraforum.com/forum/showthread.php?t=57953&p=235788)) and Standard version. Operat...
8 years ago --- Quote Start --- After you have helped to fix another issue (https://www.alteraforum.com/forum/showthread.php?t=57953), the hls/ directory is in place even in Lite version :) Now everything is fine! Thank you! --- Quote End --- Sorry. The issue is more tricky than I described first -- more info (https://www.alteraforum.com/forum/showthread.php?t=57953&p=235805#post235805)
