8 years agoHLS support in Lite and Standard versions
Hello all! I installed Quartus 17.1 Lite version (with the problems that I described here (https://www.alteraforum.com/forum/showthread.php?t=57953&p=235788)) and Standard version. Operat...
8 years ago --- Quote Start --- Hi, HLS is not supported in Lite version.You can use standard and pro version for HLS projects. Refer 1.https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/hls/ug-hls-getting-started.pdf 2.https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/hls/ug-hls.pdf In standard you may find HLS directory without examples folder. In pro HLS directory with examples. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) --- Quote End --- After you have helped to fix another issue (https://www.alteraforum.com/forum/showthread.php?t=57953), the hls/ directory is in place even in Lite version :) Now everything is fine! Thank you!
