Alexander_M_Intel
8 years agoHLS i++ Compiling Project With GTest
Hello, I am trying to compile a project written in System C that links against GTest. I would like to know how feasible this is, as I have put a decent amount of effort into making i++ play nice wi...
MuhammadAr_U_Intel
Contributor
7 years agoHi,
May I know if you have been able to execute some of the example codes provided with HLS installation ?
Located in <hls_install directory>/examples/
Secondly make sure you have updated your GCC version 5.4.0 as mentioned in Getting stater guide.
What is the Gtest ? also please elaborate on "I have projects executing successfully using i++ or gtest individually, but when I try to use both in the same project, I run into the following errors:" ?
Arslan
