HLS i++ compile failure for Quartus Prime 21.1.1 Lite
Hi @tpalomaki,
Thank you for the patients, after some alignment internally we understand that the Intel Quartus lite and Intel HLS are only supported until Windows 10. Our engineering team are still evaluating the windows 11 OS support as part of the release cycle. (More details can be found in the link : https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-software/os-support.html)
Unfortunately there is no confirm timeline for this, but tentatively the evaluation are for 22.3 cycle.
Apologies for the inconvenient cause, there might be some anomaly as you noted, we will be raising this during the evaluation period, hence for now it would be best effort support.
That said would recommend on the following steps to try below:
- Please do try on the steps mention by Microsoft to see if it helps. (https://docs.microsoft.com/en-us/answers/questions/773733/svchostexe-entry-point-not-found.html)
- There seems to be some path corruption, recommend to try uninstalled and delete the program registry followed by reinstallation to see if that work.
- Worse case if possible please do try to perform a factory reset on the Windows 11 machine and reinstall.
Hope that clarify.
BB
