HLS i++ compile failure for Quartus Prime 21.1.1 Lite
Hi @tpalomaki,
Thank you for posting in Intel community forum and hope all is well.
My guess is the sourcing of the HLS component are incomplete, or the VS studio version are incorrect in your environment.
Hence would suggest to run the init_hls.bat to check on the environment.
As for the VS support currently the latest support are for the version 2017 on hls pro version
Hope that clarify.
Best Wishes
BB
- tpalomaki4 years ago
no, the init_hls.bat (ran it as admin on windows 11) did not help, still the same "dll entry point not found" issue, win11 ~= win10.
All INFO points are being found by the script. That should work but it does not. not very robust. Shatters very easily like glass.all software (like dgpu drivers) should work out of the box, no user configuration needed, if you want to be high quality. not all are engineers.
all other components are the suggested (vs2017, win11), but all the latest tool versions should be supported.
if you need support service setting things up, the software is not complete.
