HLS Compiler (Prime 17.1): change GCC version in use
- 5 years ago
Thank you for your answer.
I am afraid I can't do as you suggest, because this version of gcc is useful for other people on the workstation.
However, this gave me an idea that I think is successful. At least I can obtain a "a.prj" directory, seemingly populated. Since I am a complete beginner in HLS, I can't say if everything worked fine.
What I did is the following :
I copied gcc and g++ executables from /usr/bin to ~/bin/ (a new, personal directory). I then added this directory to the beginning of my $PATH variable.
Then I wrote a small TCL script to find what are the necessary include directories for gcc/g++ 4.4.7.
I can then run :
$ i++ `./includes.tcl` -march="MAX 10" --fpga-only calibration_hls.c
This does the trick.
I will continue with this for a bit to see if no new problem emerge, so I leave the topic opened until then.
Regards.
PS: .tcl files are not supported, so I zipped it before attaching it.
Hi ,
Glad to know that you found a work around.
Thanks for sharing the same with the community.
Thanks and Regards
Anil
