HLS Compiler (Prime 17.1): change GCC version in use
- 5 years ago
Thank you for your answer.
I am afraid I can't do as you suggest, because this version of gcc is useful for other people on the workstation.
However, this gave me an idea that I think is successful. At least I can obtain a "a.prj" directory, seemingly populated. Since I am a complete beginner in HLS, I can't say if everything worked fine.
What I did is the following :
I copied gcc and g++ executables from /usr/bin to ~/bin/ (a new, personal directory). I then added this directory to the beginning of my $PATH variable.
Then I wrote a small TCL script to find what are the necessary include directories for gcc/g++ 4.4.7.
I can then run :
$ i++ `./includes.tcl` -march="MAX 10" --fpga-only calibration_hls.c
This does the trick.
I will continue with this for a bit to see if no new problem emerge, so I leave the topic opened until then.
Regards.
PS: .tcl files are not supported, so I zipped it before attaching it.
can you uninstall the 4.8.5 version of gcc and try to follow the instructions mentioned in the link to work with 4.4.7 version of gcc.
Thanks and Regards
Anil
- MathiasB5 years ago
I can then run :
Regards.
