Highlight routing in Chip Planner
- 3 years ago
Nope. You can leave the maximum slack limit blank.
You can report all timing paths by putting 0 at "Report number of paths", however this can be time consuming because there could be hundreds and thousands of timing paths. I would just put a large number until it starts reporting positive slack. You can also sort the paths by slack in the timing report by clicking "Slack" on the panel.
Nurina
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, please login to https://supporttickets.intel.com , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 4/5 survey
Nurina
