OLevy1
7 years agohi, i would like to implement a PCIe to PCIe bridge (ArriaV GX) between 2 Hosts (both Root Complex).
i am thinking of using 2 PCIe Cores, each will contain the same characteristics (device id, BARs...) of one of the HOSTs. basically the goal is to transfer the TLPs between one Host to another. i wou...
OLevy1
7 years agoattached.
i hope it will make the problem clearer.
as you can see in the 'Current System' drawing, the problem is that each time the Processor is rebooting, the Host must be rebooted as well so it will initiate Enumeration process and map the Processor EP PCIe to its devices.
Oren
