OLevy1
7 years agohi, i would like to implement a PCIe to PCIe bridge (ArriaV GX) between 2 Hosts (both Root Complex).
i am thinking of using 2 PCIe Cores, each will contain the same characteristics (device id, BARs...) of one of the HOSTs. basically the goal is to transfer the TLPs between one Host to another. i wou...
Abe
7 years agoLet me get this right..
- The Processor and EP sit on a separate PCB outside. Processor is connected to EP via PCIe link internally
- The Host system has a PCIe RP card in one of the PCIe slots.
- The EP and RP are connected via PCIe cable.
You want to swap out the PCIe EP on the processor side PCB to a RP and also swap the RP PCIe card in the Host system to one with an FPGA which has 2 EPs in it.
