OLevy1
7 years agohi, i would like to implement a PCIe to PCIe bridge (ArriaV GX) between 2 Hosts (both Root Complex).
i am thinking of using 2 PCIe Cores, each will contain the same characteristics (device id, BARs...) of one of the HOSTs. basically the goal is to transfer the TLPs between one Host to another. i wou...
OLevy1
7 years agohi,
sorry for the misunderstanding.
the processor is not part of the FPGA. it is currently EP, located on another PCB outside the Host. It is connected to the Host with a PCIe Cable (to the PCIe card located in the Host).
i wish to change the Processor to be Root Complex and to switch the Host PCIe Card to the Card containing the FPGA with the 2 EP PCIe Cores. the Host will be interfacing one of the FPGA EP PCIe Cores and the Processor (which is in a different PCB outside the Host) will be connected with the PCIe Cable to the other FPGA EP PCIe Core.
this way the Processor and the Host, both as Root Complex, will interface, each one of them, one FPGA EP PCIe Core.
Oren
