RReza's avatar
RReza
8 years ago
Hi, I installed Quartus Prime 18.0 Lite Edition on UBUNTU 16.04 LTS , and it is OK. But , when I start RTL simulation tool It can not lunch MODELSIM
  • SAR's avatar
    SAR
    1. To Launch Modelsim from within the Quartus II software set
    The QUARTUS_INIT_PATH variable specifies the path(s) of the EDA tool(s) to be launched from within the Quartus II software. You must set this variable to launch other EDA tools from within the Quartus II software.
    refer for more information
    https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/qts-archive/_2-5-1-quartus-install-unix.pdf
    or
    2. Set export PATH=$PATH:~/intelFPGA_lite/18.0/modelsim_ase/linuxaloem/
    Go to the directory and execute
    ./vsim
  • RReza's avatar
    RReza
    Hi, thanks for your answer, I did what you said , but when I try to execute ./vsim in that dir it dosent work saying "bash: ./vsim: No such file or directory" . I read somewhere that modelsim dosent support UBUNTU , have you ever tried that on UBUNTU?
  • SAR's avatar
    SAR
    It worked for me in Ubuntu 14.04,
    Go to /intelFPGA_lite/18.0/modelsim_ase/linuxaloem/ from terminal and type ./vsim
  • Abe's avatar
    Abe
    Have you downloaded and installed the ModelSim tool. Each of the tools have separate installers. If you have installed only the QuartsLite tool using the "Quartuslite18.0.xxx.run" file, this will install only the Quartus tools and not ModelSim. To install ModelSim, download and install the ModelSim Intel FPGA starter pack from the following link:
    http://download.altera.com/akdlm/software/acdsinst/18.0std/614/ib_installers/ModelSimSetup-18.0.0.614-linux.run
    Once the download completes, change directory to the download location and execute the following commands
    sudo chmod 775 ModelSimSetup-18.0.0.614-linux.run
    ./ModelSimSetup-18.0.0.614-linux.run
    This will launch the modelsim setup. Follow the onscreen instructions to install it. Once installed, you should be able to launch it via Quartus or terminal prompt using ./vsim command.
