I changed my code like these
before
Mode,Mode_4,Mode_16: in std_logic;
Now
Mode,Mode_4,Mode_16: inout std_logic;
and
sel
sel : in std_logic;
My project copile with now errors :D thats good
but when i start simulating CHAINE_TOP_LEVEL.vhd get this errors
vsim work.chaine_top_level(full1)
# vsim work.chaine_top_level(full1)
# Loading std.standard
# Loading ieee.std_logic_1164(body)
# Loading ieee.numeric_std(body)
# Loading ieee.std_logic_arith(body)
# Loading ieee.std_logic_unsigned(body)
# Loading work.intra16x16_type_pkg
# Loading work.intra_16x16_pkg
# Loading work.chaine_top_level(full1)
# Loading work.fsm_chaine(graphe)
# ** Failure: (vsim-3817) Port "sel" of entity "fsm_chaine" is not in the component being instantiated.
# Time: 0 ns Iteration: 0 Instance: /chaine_top_level/e_fsm_chaine File: C:/projet/FSM_CHAINE.vhd Line: 18
# Fatal error in Process line__224 at C:/projet/FSM_CHAINE.vhd line 224
# while elaborating region: /chaine_top_level/e_fsm_chaine
# Load interrupted
# Error loading design
