I fixed the errors, the project compiles but it does not simulate if you can help me fix the code multiplexer, this is the code of mux added into CHAINE_TOP_LEVEL.vhd
--------------------------------mux1-----------------------------------------------
PROCESS (sel ,Mode)
begin
case sel is
when '0' => Mode<= Mode_16;
when '1'=> Mode<=Mode_4;
when others => Mode <= Mode;
end case;
end process;
other problem when i put the variable Mode,Mode_16 and Mode_t4 on in like these
Mode, Mode_16,Mode_4 :in std_logic;
and the variable sel like these
sel :in std_logic;
when i compile the project i get this error is
Error: C:/projet/CHAINE_TOP_LEVEL.vhd(110): Cannot drive signal 'mode' of mode IN.
