Altera_ForumHonored Contributor11 years agoHelp with timequest inputs constraints Hi, I'm trying to define input constraints for an input data bus received by an A2D. The launch clock in the A2D is a derived PLL clock which is sent from the FPGA to the A2D and the latch clock is a...Show Moremultiple-attachments.zip23 KB
Altera_ForumHonored Contributor11 years agoO.K i will try to download a newer version, thank you very much for your help!
Recent Discussionsram retimingReset Release IP for Agilex needs Stratix 10 device files installed!Licensing ‘Know-How’ GuideTiming analysis - long combinational pathInvalid license key (inconsistent authentication code)
