9 years agoHelp with Shifting !
Hi everyone,
I am trying to write a vhdl program that takes a input R and a shifted version of it and adds them, then adds the result to a 2nd shifted version of R and then AND's it with a mask. (basically calculating the mod). Here is the code i have so far but i am not sure how to append Cout to the input of my AND so that i make sure to and S+Cout AND Mask : PORT ( R : IN STD_LOGIC_VECTOR(31 DOWNTO 0); MASK : IN STD_LOGIC_VECTOR(31 DOWNTO 0); OutRem : OUT STD_LOGIC_VECTOR(31 DOWNTO 0) ); END g18_lab2_RNG; ARCHITECTURE bdf_type OF g18_lab2_RNG IS COMPONENT g18_lab2 PORT(A : IN STD_LOGIC_VECTOR(31 DOWNTO 0); B : IN STD_LOGIC_VECTOR(31 DOWNTO 0); Cin : IN STD_LOGIC; S : OUT STD_LOGIC_VECTOR(31 DOWNTO 0); Cout : OUT STD_LOGIC ); END COMPONENT; SIGNAL SYNTHESIZED_WIRE_0 : STD_LOGIC; SIGNAL SYNTHESIZED_WIRE_1 : STD_LOGIC_VECTOR(31 DOWNTO 0); SIGNAL SYNTHESIZED_WIRE_2 : STD_LOGIC_VECTOR(31 DOWNTO 0); SIGNAL RShift1: STD_LOGIC_VECTOR(31 DOWNTO 0); SIGNAL RShift2: STD_LOGIC_VECTOR(31 DOWNTO 0); BEGIN RShift1 <= STD_LOGIC_VECTOR(unsigned(R)sll 1); RShift2 <= STD_LOGIC_VECTOR(unsigned(R)sll 16); b2v_inst : g18_lab2 PORT MAP(A => R, B => RShift1, Cin => '0', S => SYNTHESIZED_WIRE_1, Cout => SYNTHESIZED_WIRE_0); b2v_inst2 : g18_lab2 PORT MAP(A => RShift2, B => SYNTHESIZED_WIRE_1, Cin => SYNTHESIZED_WIRE_0, S => SYNTHESIZED_WIRE_2, Cout => ; OutRem <= SYNTHESIZED_WIRE_2 AND MASK; END bdf_type; EDIT: i figured out i can use & to concatenate bits so i changed my Cout to : Cout => SYNTHESIZED_WIRE_3 and then : OutRem <= SYNTHESIZED_WIRE_3 & SYNTHESIZED_WIRE_2 AND MASK;1 Reply
Are you aware of the 'mod' operator in VHDL?
Have a look at: http://stackoverflow.com/questions/25848879/difference-between-mod-and-rem-operators-in-vhdl then have a play with the operator. I think it'll allow you to clean up your code a little... or maybe quite a bit. Cheers, Alex
