11 years ago --- Quote Start --- Thank you. I see that you have used filename.mif, is that from MATLAB? Is there a way to write the same program, say using a basic simulator like ModelSIM? Regards, Manoj --- Quote End --- Yes that is matlab geneartion I believe you can write text file in Modelsim in same way. run a counter 0_1023 set values for signal temp as your values depending on counter value then write text file out.
