CHerb4
7 years agoHelp to translate verilog to vhdl
Greetings, first to say that I am new to the forum and I really do not know if this is the correct section for this type of questions.
I have limited knowledge in vhdl but I am totally new in verilog. A couple of days ago I try to translate a project from verilog to vhdl, for this I am using a translator, but even so I am finding lines that I can not translate to vhdl (lines 1, 2, 3, 8, 11, 15, 36, 51).
`define SDREADRANGE 16*idx+15:16*idx // Incrementing indexes within generate below
`define SBUSRANGE 32*idx+31:32*idx // Incrementing indexes within generate below
`define SDRECRANGE 9*idx+8:9*idx // Incrementing indexes within generate below
generate
genvar idx;
for (idx=0; idx<=31; idx = idx+1)
begin : sdma_engines
// Create a unique register block address: 32 SDMA engines with 64 bytes each = 2K
wire i_aen = i_aen_sdma_engines & (i_host_addr[10:6] == idx );
wire [31:0] sdma_dq = i_sdma_dq[`SBUSRANGE];
wire [8:0] sdma_record_size = i_sdma_record_size[`SDRECRANGE];
// SDMA engines use PTIQ's 8-(31+8)
wire [7:0] ptiq_number = 8'd8 + idx;
g1_sdma_engine U_sdma_engine (
// Clock and Reset
.i_rst ( i_rst ), // input //
.i_clk ( i_clk ), // input //
// ======= Local Bus Interface =======
.i_lclk ( i_lclk ), // input //
.i_host_addr ( i_host_addr[5:1] ), // input [5:1] //
.i_cs ( i_cs ), // input //
.i_rnw ( i_rnw ), // input //
.i_aen ( i_aen ), // input //
.i_host_data ( i_host_data ), // input [15:0] //
.o_host_data ( odata_engines[`SDREADRANGE] ), // output [15:0] //
.o_ta ( sdma_otas[idx] ), // output //
// Interface to source logic
.i_sdma_enc ( i_sdma_enc[idx] ), // output //
.i_sdma_record_added_tk ( i_sdma_record_added_tk[idx] ), // input //
.o_sdma_ffren ( o_sdma_ffren[idx] ), // output //
.i_sdma_ff_almost_full ( i_sdma_ff_almost_full[idx] ), // input //
.i_sdma_dq ( sdma_dq ), // input [31:0] //
.i_sdma_eof ( i_sdma_eof[idx] ), // input //
.i_sdma_record_size ( sdma_record_size ), // input [8:0] //
// Backplane Interface via arbiter. Write fully-formed TLP's
.o_tlp_request ( s_request[idx] ), // output //
.i_tlp_grant ( s_grant[idx] ), // input //
.o_tlp_data ( s_data[`SBUSRANGE] ), // output [31:0] //
.o_tlp_eof ( s_eof[idx] ), // output //
.o_tlp_wen ( s_wen[idx] ), // output //
// ptiq
.i_ptiq_number ( ptiq_number ), // input [7:0] //
.o_ptiq_dav ( o_sdma_ptiq[idx] ) // output //
end
endgenerateCualquier ayuda es muy bienvenida, gracias de antemano.
