11 years agoHo! Thank you very much! It's not cool because the default value is not with the last "/" and when we select the path, the "/" is not add.
Than you for your help, it works now!Ho! Thank you very much! It's not cool because the default value is not with the last "/" and when we select the path, the "/" is not add.
