17 years agoThe cascade of two FF recommendation is considering the rare condition of metastable states, for most designs single FF synchronizers are sufficient to my opinion.
There may be however a problem with multibit signals (e. g. representing a number) which have to be transmitted coherently across the clock domain border. These signals need either gray encoding or you have to establish a handshake to avoid inconsistent results. Otherwise, if you have a 4-bit value changing from 0x7 to 0x8, it may be read also as 0x0 or 0xf due to delay skew.
