10 years agoHelp needed in VHDl code for calculating the I and Q phase component for a ADC signal
Hello all, I am designing a DDC in which I need to calculate the In phase(I) and the Quadrature phase(Q) components of my ADC signal. I know how these components are manually calculated from som...
10 years ago --- Quote Start --- I'm not clear about your problem. If you have the decimated output, you have the I/Q components, provided you have already multiplied your ADC signal in the mixer. Your ADC should go through Mixer, then through decimation process. IS it the correct order in your implementation? I guess that you mean you have no Mixer before decimation. --- Quote End --- Hi, I have a mixer before decimation. But at the output, I have it as a single digital output from which I need to find the I and Q phase components separately. I mean like "111100011101010100..." something like this. I need to decompose this output into I and Q components separately. How to do this in VHDL. Can you suggest me any way of finding this out. Thanks in advance.
