10 years agoHelp needed in VHDl code for calculating the I and Q phase component for a ADC signal
Hello all, I am designing a DDC in which I need to calculate the In phase(I) and the Quadrature phase(Q) components of my ADC signal. I know how these components are manually calculated from som...
10 years agoI'm not clear about your problem.
If you have the decimated output, you have the I/Q components, provided you have already multiplied your ADC signal in the mixer. Your ADC should go through Mixer, then through decimation process. IS it the correct order in your implementation? I guess that you mean you have no Mixer before decimation.
