10 years agoHelp needed in VHDl code for calculating the I and Q phase component for a ADC signal
Hello all, I am designing a DDC in which I need to calculate the In phase(I) and the Quadrature phase(Q) components of my ADC signal. I know how these components are manually calculated from som...
10 years agoI assume you have typing mistakes in your last post as well as in your previous diagram.
I don't want to move away from your original post but I asked about sampling rate after ADC i.e. input to mixer and clock speed there. By sampling rate I mean data sample rate at its given width (not bit rate). you also have 8 x something. is your data split up into 8 parallel streams or is that 8 independent channels of data. Without clear answers I really can't help
