10 years agoHelp needed in VHDl code for calculating the I and Q phase component for a ADC signal
Hello all, I am designing a DDC in which I need to calculate the In phase(I) and the Quadrature phase(Q) components of my ADC signal. I know how these components are manually calculated from som...
10 years ago --- Quote Start --- you have already done that at mixer output. However I am not clear about other things. how you process at such high sample rate after ADC --- Quote End --- Actually, in the decimation process, I reduce the sampling rate of the ADC signal by performing the decimation by 8, where the mixer output undergoes FIR filtering followed by down sampling by 8. Isn't this enough?
