10 years agoHelp needed in VHDl code for calculating the I and Q phase component for a ADC signal
Hello all, I am designing a DDC in which I need to calculate the In phase(I) and the Quadrature phase(Q) components of my ADC signal. I know how these components are manually calculated from som...
10 years ago --- Quote Start --- Sorry its my fault. What I meant is that I have a digital output of a Decimated ADC signal from which I need to calculate the I phase and Q phase components for this signal. --- Quote End --- you have already done that at mixer output. However I am not clear about other things. how you process at such high sample rate after ADC
