10 years agoHelp needed in VHDl code for calculating the I and Q phase component for a ADC signal
Hello all, I am designing a DDC in which I need to calculate the In phase(I) and the Quadrature phase(Q) components of my ADC signal. I know how these components are manually calculated from som...
10 years agoYou'd better to post your DSP block diagram. Most of DSP applications can be partitioned to separate blocks. Each of them can be coded manually or instantiated as a ready IP Core from Megawizard for example.
Controller of DSP applications is rather simple, at least to control-dominated applications like a CPU.
