8 years agoHelp multiplier vhdl
Hi everyone! I've some problems with a design, I have to Design an algorithmic state machine to implement a parallel series multiplier for eight-bit numbers encoded in SM (Sign-Magnitude). The mul...
8 years agohere is my go without sim and without sign bit output.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.numeric_std.all;
entity prueba2 is
port (
A : in std_logic_vector (7 downto 0);
B : in std_logic_vector (7 downto 0);
inicio : in std_logic;
clk : in std_logic;
reset : in std_logic;
q : out std_logic_vector (2 downto 0);
resultado : out std_logic_vector (15 downto 0)
end prueba2;
architecture behavioral of prueba2 is
signal y : unsigned(15 downto 0);
begin
multi : process (clk, reset)
variable cuenta : unsigned(2 downto 0);
variable temp : unsigned(15 downto 0);
begin
if reset = '1' then
--reset all
elsif clk'event and clk = '1' then
if inicio = '1' then
cuenta := cuenta + 1;
end if;
q <= std_logic_vector(cuenta);
temp := (others => '0'); --default
y <= y + temp;
if cuenta = "000" then --update output
resultado <= std_logic_vector(y);
end if;
case cuenta is
when "000" =>
if A(0) = '1' then
temp := "00000000"&unsigned(B);
end if;
when "001" =>
if A(1) = '1' then
temp := "0000000"&unsigned(B)&'0';
end if;
when "010" =>
if A(2) = '1' then
temp := "000000"&unsigned(B)&"00";
end if;
when "011" =>
if A(3) = '1' then
temp := "00000"&unsigned(B)&"000";
end if;
when "100" =>
if A(4) = '1' then
temp := "0000"&unsigned(B)&"0000";
end if;
when "101" =>
if A(5) = '1' then
temp := "000"&unsigned(B)&"00000";
end if;
when "110" =>
if A(6) = '1' then
temp := "00"&unsigned(B)&"000000";
end if;
when "111" =>
if A(7) = '1' then
temp := "0"&unsigned(B)&"0000000";
end if;
end case;
end if;
end process;
end behavioral;
