8 years agoHelp multiplier vhdl
Hi everyone! I've some problems with a design, I have to Design an algorithmic state machine to implement a parallel series multiplier for eight-bit numbers encoded in SM (Sign-Magnitude). The mul...
8 years ago --- Quote Start --- take this example: A = 1111101 B = 1111111 y = 0 count = 0 , A(0) = '1' hence result of A(0) *B = B (1111111), I called it temp update sum: y = y+temp; count <= count + 1; count = 1 , A(1) = '0' hence result of A(1) *B = 0, I called it temp update sum: y = y+temp&'0'; --shift temp by one bit count <= count + 1; count = 2 , A(2) = '1' hence result of A(2) *B = B, I called it temp update sum: y = y+temp&'00'; --shift temp by two bits count <= count + 1; ... --- Quote End --- I've been working in this project and I've get this: library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.std_logic_unsigned.all; use IEEE.numeric_std.all; entity prueba2 is port ( A : in std_logic_vector (7 downto 0); B : in std_logic_vector (7 downto 0); inicio : in std_logic; clk : in std_logic; reset: in std_logic; q : out std_logic_vector (2 downto 0); resultado : out std_logic_vector (15 downto 0) ); end prueba2; architecture behavioral of prueba2 is begin multi : process (A, clk, reset) variable y : std_logic_vector (15 downto 0); variable cuenta : std_logic_vector (2 downto 0); variable temp : std_logic_vector (7 downto 0); begin if reset = '1' then y:= "0000000000000000"; else if clk'event and clk = '1' and inicio = '1' then cuenta := cuenta + 1; end if; q <= cuenta; end if; case cuenta is when "000" => if A(0) = '1' then temp := B; else temp := "00000000"; end if; y := y + temp; when "001" => if A(1) = '1' then temp := B; else temp := "00000000"; end if; y := y + temp&"0"; when "010" => if A(2) = '1' then temp := B; else temp := "00000000"; end if; y := y + temp&"00"; when "011" => if A(3) = '1' then temp := B; else temp := "00000000"; end if; y := y + temp&"000"; when "100" => if A(4) = '1' then temp := B; else temp := "00000000"; end if; y := y + temp&"0000"; when "101" => if A(5) = '1' then temp := B; else temp := "00000000"; end if; y := y + temp&"00000"; when "110" => if A(6) = '1' then temp := B; else temp := "00000000"; end if; y := y + temp&"000000"; when "111" => if A(7) = '1' then temp := B; else temp := "00000000"; end if; y := y + temp&"0000000"; end case; resultado <= y; end process; end behavioral; ------------------------------------------- But there is an error when I do y := y + temp&"0"; because expression has 17 elements, but must have 16 elements. How can I correct this?
