8 years agoHelp multiplier vhdl
Hi everyone! I've some problems with a design, I have to Design an algorithmic state machine to implement a parallel series multiplier for eight-bit numbers encoded in SM (Sign-Magnitude). The mul...
8 years agoThank you kaz, but how can I do that in VHDL??
I know how I have to do the operation, but I don't know how to create the register in VHDL. Right now, I have this: library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.std_logic_unsigned.all; use IEEE.numeric_std.all; entity reg_des is port ( multiplicador: in std_logic; multiplicando: in std_logic_vector (7 downto 0); registro7: out std_logic_vector (7 downto 0); registro6: out std_logic_vector (7 downto 0); Q7: out std_logic; resultado: out bit_vector (15 downto 0); clk: in std_logic; reset: in std_logic); end reg_des; architecture behavioral of reg_des is begin reg_des : process (multiplicador, clk, reset) variable Q : std_logic_vector (8 downto 0); begin if reset = '1' then Q:= "000000000"; else if clk'event and clk = '1' then for i in 0 to 7 loop Q(i) := Q(i+1); if i = 0 then registro7(7) <= Q(i) and multiplicando(7); end if; if i = 1 then registro7(6) <= Q(i) and multiplicando(7); registro6 (7) <= Q(i-1) and multiplicando(6); end if; if i = 2 then registro7(5) <= Q(i) and multiplicando(7); registro6 (6) <= Q(i-1) and multiplicando(6); end if; if i = 3 then registro7(4) <= Q(i) and multiplicando(7); registro6 (5) <= Q(i-1) and multiplicando(6); end if; if i = 4 then registro7(3) <= Q(i) and multiplicando(7); registro6 (4) <= Q(i-1) and multiplicando(6); end if; if i = 5 then registro7(2) <= Q(i) and multiplicando(7); registro6 (3) <= Q(i-1) and multiplicando(6); end if; if i = 6 then registro7(1) <= Q(i) and multiplicando(7); registro6 (2) <= Q(i-1) and multiplicando(6); end if; if i = 7 then registro7(0) <= Q(i) and multiplicando(7); registro6 (1) <= Q(i-1) and multiplicando(6); end if; if i = 8 then registro6 (0) <= Q(i-1) and multiplicando(6); end if; end loop; Q(8):=multiplicador; Q7 <= Q(7); end if; end if; end process; end behavioral; ------------------------------------------------------ Is this the correct way to do it?? Thank you!
