--- Quote Start ---
Can you give more details about the project? Do you use 7 segments displays? A led blinking? Are you using an Altera kit? Do you make your own hardware?
--- Quote End ---
Ok, so yes we are using an Altera board, and we want the LEDR's above the switches to represent the time remaining on the board. We want the game to last a minute, and there are 18 LEDR's we want to use (The red ones). so one LEDR has to turn off every 60/18= 3+1/3 seconds.
My initial Idea was to divide the clock out to a frequency like 3.333 HZ and then on every Posedge of the clock turn a light off, and count up like time=time+1. so once time>=18, the module would output a signal to terminate the game.
After reading Ted's post it sounds like what I am trying to do is more complicated then I thought. I will give Ted's link a read.
