The above posts are all correct - you need to choose a maximum size for your vector. The only thing I'd add is that you could use a generic to more easily change the maximum length. This would mean that if a different design used a different vector length you could use the same piece of code just change the generic map in your component instantiations.
e.g.
entity your_block is
generic (max_vector_length : integer := 10)
port (
-- the ports in your design
end your_block;
then in your designs when you instantiate this block:
design1 : your_block
generic map (max_vector_length => 20);
port map (
-- as usual
design2 : your_block
generic map (max_vector_length => 37);
port map (
-- as usual
Essentially because the generic value is known at compile time it is like a constant. It just allows you to more easily change the value and reuse your code more easily.
Hope this helps.
